Old Webster Hone
Acesales
New User
I've had this old pin hone for years. It was made by Webster Products Company, Cleveland, Ohio. I'd like to start using it in my repair shop for hobby purposes. Does anyone have any info out there? Thanks
I had that almost exact machine .Mine was a bit larger. I found no info ever . Someone said a company had adapters {maybe Superior Hone] Never found them Then I got a Sunnen and cut the top off my Webster and mounted a plate for a Sunnen Hone .So the Webster was used only for the oil tray. When I did Harley cylinders I had a Snap-On hone adapted to a nut from the Wenster which I then could hone a 3 something inch bore . Not much info on these they seem rare. Good luck with yours !
Interesting! I looked through and found your post from years ago. These seem fairly rare. Even the great google has just about no info at all on them.
I noticed someone said they have a manual for it, username oly1212 or something? Did you ever get a copy from him? Thanks
That looks like a piston pin hone. I am thinking it should have a whole box of attachments that go on the shaft. They should be with it if you really want to use it.
