use pipe for return line on back-hoe.
The hydraulic return hose on back is broken, almost impossible to get it out without cutting it in pieces. Could I use regular pipe part way and then hydraulic hose. There is no pressure on the large return line. Thanks for any help.
Tubing is larger internally for the same OD. and less expensive as well. Metal supply stores have it. Jim
