Company Logo Shop Now
Tool Talk Discussion Forum
Re: It must be Monday.
daisyman
07-17-2020 11:31:30
Sounds familiar. Back tire and battery both went flat on my JDLX178 mower on the same day last week. Took the battery out and put a syringe full of water in EACH cell.....MY BAD. Battery's OK. Tire has a tube in it, and had a small hole in it. Never found anything in the tire....patched the tube, put it back together, smiling. Went to mow this week, tires flat!! Pulled it apart (not fun) again, aired it up with a vengence, put it in a 55 gal barrel of water.....no leaks! GRRRR! Put it back on this morning, we'll see!
Irv
Southern Ray
07-17-2020 16:12:29
 Re: It must be Monday. in reply to daisyman, 07-17-2020 11:31:30
Put more air in it to check for leaks.
I once chased a leak for three tries over two weeks and couldn't find it. But the tire kept going down.
Last time I put more air in it and found the leak. The hole was too tiny to make bubbles until I put more pressure in the tube.
daisyman
07-17-2020 20:50:35
 Re: It must be Monday. in reply to Southern Ray, 07-17-2020 16:12:29
When I say I aired it up with a vengence, it's an 18/8.50/x8 and I could just barely get it in a 55 gallon barrel diameter. It's still up this afternoon!! Musta done something right. However, that battery problem turned out to be four burned spade terminals in the connector to the voltage regulator. (each end of two pair of wires). Can't get them out of the connector either. Gonna have to wait for another day, I'm wore out and going to bed. Hot and humid here today, (upper 90's) same tomorrow. Can't take the heat no more.
Irv
Copyright © 1997-2020 Yesterday's Tractor Co.
