Company Logo Shop Now
Tool Talk Discussion Forum
leak
504
07-16-2020 21:29:44
At work they bought a large carport that we use as a shelter for our LP filling station.They bought it on the net and had a local guy put it up. The problem is the massive leak when it rains from the west(it always rains from the west). The tin is overlapped a good two feet but it is lapped the wrong way,anyone have an easy way to seal the joint? We really do not care about looks and they are never going to let me take it apart to caulk the overlap. Miracle tape? roofing dope?
DoubleO7
07-17-2020 07:35:37
 Re: leak in reply to 504, 07-16-2020 21:29:44
If you can remove a few screws and lift the edge up enough, install a line of butyl rubber tape under at the edge.
Like this:https://www.homedepot.com/p/Fabral-1-4-in-x-40-ft-Butyl-Rubber-Sealant-Tape-40BT/207149821
stroby
07-17-2020 05:35:52
As you know, the right way is to lap it the right way. Having said that, I use a product called "Through the Roof" that is amazing for roof repair. It can be bought in a tube, or container and applied with a putty knife or brush. It is clear, and does a SUPER job of seal anything, even leaking gutter joints. My two cents.
504
07-17-2020 15:44:41
 Re: leak in reply to stroby, 07-17-2020 05:35:52
That is what we need thanks.
RM-MN
07-17-2020 03:42:20
Don't ask if you can take it apart to fix the leak, just do it. Sealing that wrong way lap will be a temporary solution and not a good one for temporary even. Make the lap the right way and never touch it again.
rrlund
07-17-2020 03:40:00
3M Weather Strip Adhesive. Get the black stuff in the large tube, not the greenish in the small tube.
Mark-IA
07-16-2020 23:30:44
get about 4 guys, lift it up and turn it 180 degrees. The lap would face the other way.
Copyright © 1997-2020 Yesterday's Tractor Co.
