Company Logo Shop Now
Tool Talk Discussion Forum
Vinyl Glue
Angus Thom
07-16-2020 11:39:23
Not sure this is right forum - but I need to repair the toe plate of a 50+ yr old Kenmore trash compactor. Toe plate is 3/32 vinyl - currently only held at the 3 little places indicated. Any suggestions on the best glue? Im also thinking to sister something across the tear to reinforce that glue line - any suggestions there? Of course if anyone has a spare part . . . it 665.8406 777276 :-) TIA
Ted in NE-OH
07-18-2020 20:55:57
 Re: Vinyl Glue in reply to Angus Thom, 07-16-2020 11:39:23
Flex Tape
JIM MN
07-17-2020 13:54:55
I agree with Duner Wi.... Shoe-Goo... Good stuff.. Put a good bead on the vinyl; both sides -let cure, it will be good to go for a long time. Great glue for other things too..
Duner Wi
07-17-2020 09:34:33
No guarantee but I have had Shoe Goo stick to vinyl real good.
Pete in Holland MI
07-16-2020 19:35:32
Bout the best you can do is cut out something to back that up with (vinyl flooring?) and glue it to the original piece.
Contact cement should work, along with general purpose flooring adhesive. Clean both surfaces well. Apply glue to 100% of the surface. Clamp between two boards to wet out the adhesive and hold the composite flat.
Crack will still be present, but less visible.
Angus Thom
07-16-2020 18:52:47
Many Thanks all . . . good ideas - I've no experience w/ gorilla tape but that could certainly be a good sister support mechanism to the contact cement glue line. That will be plan A (repair existing) . . . the vinyl base coving will be plan B (replacement). Angus
old560
07-16-2020 13:38:36
Used to do floor covering whenever we have vinyl base to put on weird angles we would use contact cement worked good
old560
07-16-2020 13:31:17
Contact cement?
dleefarms
07-16-2020 12:49:50
Try using Gorilla tape on each side. First one side and cut out the openings then the other side. I just repaired a disc mower cover the same way with no issues.
Angus Thom
07-16-2020 12:00:21
Going to be a problem clamping & keeping pressure on such a long thin glue line.
Angus Thom
07-16-2020 11:59:19
there's some molding/shapes i couldnt replicate - but its an aidea - I could perhaps just replace the flatter piece. Thanks.
Ted in NE-OH
07-16-2020 11:47:59
Gorilla glue
Janicholson
07-16-2020 11:44:41
How about making a new one out of vinyl base molding used at the wall floor joint. Jim
used red mn
07-16-2020 16:47:26
 Re: Vinyl Glue in reply to Janicholson, 07-16-2020 11:44:41
Something like this...
Janicholson
07-16-2020 19:23:02
 Re: Vinyl Glue in reply to used red mn, 07-16-2020 16:47:26
yes. It just is near impossible to fix vinyl with glue. If successful, the patch is ridged and easily fails. Jim
Copyright © 1997-2020 Yesterday's Tractor Co.
