Need small powerful compressor
I have a Porter Cable that is pretty good. Loud enough to wake the dead but otherwise good. I got it to carry around the house during remodel. They say portable but heavy enough to be crew-served in my book.
(quoted from post at 14:25:16 07/15/20) Who makes a small compressor I could use to put 110 psi into the air tank on my bike ?
f you are speaking of a small volume, any old refrigerator or freezer compressor will get you the pressure, 110, very easily & generally are free to anyone that will haul them away.
> Air shifter
I never knew such a thing existed! So I guess you need something small that you can pack up when you ride in case you happen to run out of air out in the boonies. So it needs to be small, capable of over 100 psi and preferably 12vdc powered.
Have you considered something intended for bicycles? I see there are some battery-powered rechargeable ones available if you google "miniature electric bicycle pump".
Nitrogen bottle and regulator from the welder's supply? One bottle would likely last a long time. You could probably find a used regulator on ebay. I have a setup that I use for auto A/C work as well to run air tools in remote locations etc.
Garry
Most of the small 12 volt emergency air compressors for carrying in a car can reach 125+ PSI. They are slow, but inexpensive, $25 on up on Amazon.com.
