Company Logo Shop Now
Tool Talk Discussion Forum
Wheel hub dust caps
Ricey06
07-15-2020 13:04:20
Maybe a simple/stupid question but how do you remove the caps without damaging them? I need to put new tires on my splitter therefore I need to get the wheels off. Thanks Jeff
kevinstuff
07-16-2020 16:39:32
 Re: Wheel hub dust caps in reply to Ricey06, 07-15-2020 13:04:20
My 08 focus has almost flat caps and no gap To pry upon , if any mechanic is willing to share the best tool , method , Thanks !
timcasbolt
07-16-2020 05:00:57
Here is a tool you can purchase for this purpose: https://www.amazon.com/Vim-Tools-V216-Dust-Plier/dp/B000X2533Y/ref=asc_df_B000X2533Y/?tag=hyprod-20&linkCode=df0&hvadid=309807921328&hvpos=&hvnetw=g&hvrand=14390452484967236645&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008121&hvtargid=pla-495097918257&psc=1
MarkB_MI
07-16-2020 04:27:16
I always drive a chisel or screwdriver between the cap and hub.
Steve@Advance
07-15-2020 17:38:35
That style is easy to pull with Channel Locks.
If it collapses them a little, just put a piece of round stock in the vise, just smaller then the ID of the cover. Tap it back round with a small hammer.
LonM
07-15-2020 17:31:46
I take a cold chisel and drive it between the hub and the cap a little bit at a time in several places around the cap until it is loose enough to pull off by hand.
Ellis Kinney
07-15-2020 17:13:23
I have a really tiny pry bar that I use. Ellis
svcummins
07-15-2020 15:41:31
They are about 3$ each or a little less I wouldn’t worry much about ruining it
Davebn
07-15-2020 15:41:17
I wiggle or drive a screwdriver behind the ring and pry them off.
A chisel or hard piece of wood on that same ring to put it back on.
Depending on how tight they fit you will have to go around it a few time when taking it off and putting it back on.
Dave
gab
07-15-2020 15:28:42
I got ma Snap On tool made for that but a big channel locks works good too.
ricey06
07-15-2020 13:57:27
I tried tapping with a dead-blow,no luck. I was afraid channel locks would crush them. They have been on about 18 yrs. without ever being removed.I'll try to use the channels carefully. Thank you
Russ from MN
07-15-2020 13:20:58
I have used a channellock too, or a soft hammer, just go round and round. you need the soft hammer to put them back in the hub anyhow. Maybe you should just let the tire shop do it?
DoubleO7
07-15-2020 13:08:26
I use big channel locks parallel to spindle and wiggle while pulling.
Copyright © 1997-2020 Yesterday's Tractor Co.
