Company Logo Shop Now
Tool Talk Discussion Forum
Need small powerful compressor
dr sportster
07-15-2020 11:25:16
Who makes a small compressor I could use to put 110 psi into the air tank on my bike ?
ss55
07-16-2020 16:58:30
 Re: Need small powerful compressor in reply to dr sportster, 07-15-2020 11:25:16
Most of the small 12 volt emergency air compressors for carrying in a car can reach 125+ PSI. They are slow, but inexpensive, $25 on up on Amazon.com.
GarryinNC
07-16-2020 13:36:24
Nitrogen bottle and regulator from the welder's supply? One bottle would likely last a long time. You could probably find a used regulator on ebay. I have a setup that I use for auto A/C work as well to run air tools in remote locations etc.
Garry
JMOR
07-16-2020 09:48:04
Air ride pump off an old Cadillac is 12v & small, too.
MarkB_MI
07-16-2020 03:16:42
Curious about this "air tank on my bike". You got air suspension?
dr sportster
07-16-2020 06:03:46
 Re: Need small powerful compressor in reply to MarkB_MI, 07-16-2020 03:16:42
Air shifter
MarkB_MI
07-16-2020 08:47:48
 Re: Need small powerful compressor in reply to dr sportster, 07-16-2020 06:03:46
> Air shifter
I never knew such a thing existed! So I guess you need something small that you can pack up when you ride in case you happen to run out of air out in the boonies. So it needs to be small, capable of over 100 psi and preferably 12vdc powered.
Have you considered something intended for bicycles? I see there are some battery-powered rechargeable ones available if you google "miniature electric bicycle pump".
dr sportster
07-16-2020 11:38:00
 Re: Need small powerful compressor in reply to MarkB_MI, 07-16-2020 08:47:48
No but I will check it out . Bike shifts normal without air if desired
mark1955
07-15-2020 15:43:33
try the battery operated drill compressor, you will be supprised.
JMOR
07-15-2020 13:32:56
Quoting Removed, click Modern View to seeIf you are speaking of a small volume, any old refrigerator or freezer compressor will get you the pressure, 110, very easily & generally are free to anyone that will haul them away.
MarkB_MI
07-15-2020 12:50:55
How small? 120vac or 12vdc?
Steve in VA
07-15-2020 11:39:57
I have a Porter Cable that is pretty good. Loud enough to wake the dead but otherwise good. I got it to carry around the house during remodel. They say portable but heavy enough to be crew-served in my book.
keith molden
07-15-2020 14:43:50
 Re: Need small powerful compressor in reply to Steve in VA, 07-15-2020 11:39:57
x 2 on the porter cable. I use mine quite a lot but it sure is noisy.
Copyright © 1997-2020 Yesterday's Tractor Co.
