Ok this was on the big bridge job I have been working on today. All the bridge I beams are set. Today a company
came in and welded steel studs perpendicular to the beams on top of them. Then they took aluminum angle iron
and welded them to the steel studs. The welder was a Miller Bobcat. These angles support steel pans which the
bridge deck is poured on. I didn’t have a chance to talk to the welders. So what rod would weld the aluminum angle
to the steel studs ?
