Company Logo Shop Now
Tool Talk Discussion Forum
Re: Graphite Rods and Brazing
DoubleO7
07-14-2020 18:23:01
Without a mill, how are you going to get a 1.66" dia. Hole for the 1-1/4" pipe exactly where it needs to be? Will the 1 .38 inside dia. Of the pipe be good enough? Common ERW pipe will have a light weld seam inside. Might have to use seamless.
Weirddeere
07-14-2020 20:07:58
 Re: Graphite Rods and Brazing in reply to DoubleO7, 07-14-2020 18:23:01
The diameter should be doable, even if it needs a little finessing. Die grinder might clean up any internal welding.
Locating the pipe would be tough and I'm thinking up solutions, maybe welding it onto a plate on one side that will locate it while I do whatever else in the mess that is the original bore. I think braze but not sure. Then cut it off when done.
I'm thinking out loud.
Will it be a super precise fix, no, but a LOT better then how it is now and should be durable to last for my hobby use
Brandon
Copyright © 1997-2020 Yesterday's Tractor Co.
