Tool Talk Discussion Forum
Re: Just and FYI for anybody wanting to UP GRADE shop litesto LE
Oldfarmtractor
06-25-2020 15:35:09
I have been converting all bulbs to LEDs at a rate that works for me. The first were the outside ones that are on all night. I replaced those over 5 years ago and they are going great. I then started some of the screw in bulbs inside, again success.
Time to change the 4' fluorescent bulbs to LEDs. I changed a couple in the garage, remove the ballast and then wire a hot and neutral to one end of the fixture. Only one has failed and that is because it fell out of the fixture. So a year later I buy another box and these are wired differently. Remove the ballast and one end of the bulb is hot, the other end is neutral. But they are so bright!
In the shed, I have replaced the bulb holders with outlets and hung 3" all over the place.
No temperature probems, always over 4500K for brightness.
