Holley carb Identification
its a 4160, but to get the designed-for CFM you need the list number off of the choke air horn, usually it is stamped on the left front quadrant just above the float bowl.
Holley I.D.
(quoted from post at 08:54:08 03/31/20) Can you tell how many CFM a Holley carb is by looking at it ?
Need to identify what you have.
Not sure about tractor carbs but generally speaking there should be a Holley list number on the choke tower, example; LIST 3310.
Original equipment Holley carbs might have application specific OEM nomenclature as well.
(quoted from post at 09:26:24 03/31/20) the last picture in this ad shows the list number, I just cant make it out- contact the seller?
My bad. I didn't click the link first. From the bracing on the body side I would say it a later, generic aftermarket Holley carb. The side hung floats, inlet location, cross-bar boosters, vacuum secondaries and from what I can see of the venturi size - no bigger than 600.
