Idaho Digger
Howdy all,
Not exactly a tool question, but I'm using a bunch on this remodel (-;
I'm running a new lighting circuit with 4 recessed LED's controlled by 2 3-way switches, one with a dimmer. From looking at lots of diagrams and getting a little confused, can I run power from the panel to either 3-way switch, then all I need to do is run a red jumper between the 2 3-way switches? can 14/2(w/g) be run from either switch, then run normally to the 4 cans? Power from the panel is already run into one switch box, the one getting the dimmer. Some of the diagrams I pulled show a red jumper to each of the 4 cans....
Thanks in advance!
Scott
Thanks in advance!
Scott
