Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
Generator head for the CC
Greenfrog
01-23-2020 13:12:23
I have a CC 128 and a 129.
I want to mount a generator(generator head) to the front and use the front PTO pulley. Hang on the front, gen. shaft under the grill....
I want to use the 2600 generator from Northern Tool and Equipment. Pincor use to make such....just for attachment to these lawn tractors
I see numerous setups like this on the internet
Has anybody out there done such?
What size pulley?
How fast does one run the engine? They have 12hp
What is the rpm of a CC engine? Letís say at half throttle....
The generator is to be run at about 3600rpm for optimal output
I can rig up a mount using the mower deck front attachment...unless someone has another idea
Iím trying to get away from a portable generator that would have to be started once a month (should be!), stale gas, additives, and just sitting around. The tractors get used frequently, one for mowing, other for plowing, snow removal and general yard work Thx in advance for any discussion on this and for your input..
Greenfrog
01-31-2020 16:21:27
 Re: Generator head for the CC in reply to Greenfrog, 01-23-2020 13:12:23
Thanks to all for the good info and discussion on my topic. Thx to YT for providing the forums to do such.
Greenfrog
01-27-2020 18:20:24
When I bought my JD 235 back in 2001, they made a GT235E. Electric, had onboard inverter. Wish I would have bought that.🤔😟
Tom Massachusetts
01-27-2020 07:06:20
Cub Cadet = CC
wilson ind
01-26-2020 13:52:18
Are you talking about a Case Model CC . Sorry read whole post and have no idea what CC you are meaning??
DoubleO7
01-26-2020 09:33:36
Quoting Removed, click Modern View to seeyes and the first ones offer thru IH were mounted on the side of the tractor so it so it did not have to be removed to use most implements.
I would look hard at doing it on the side as well with a bracket or hinge point that can stay on full time. Then be able to quickly hang the generator on it and the belt.
Do the wide frame CC's have the pully on the crank where the drive shaft connects? Changing that one to a bigger one might be an idea to look into.
Greenfrog
01-27-2020 18:16:50
 Re: Generator head for the CC in reply to DoubleO7, 01-26-2020 09:33:36
Interesting point. I thought about that. Is there room to bring up/out a belt from that front PTO pulley?
DR. EVIL
01-28-2020 03:21:31
 Re: Generator head for the CC in reply to Greenfrog, 01-27-2020 18:16:50
The starter/generator is belt driven already on the right side, your AC generator would have to be mounted even further to the right and THAT puts it a long way from the engine. Would probably be best to drive the AC generator off the pulley on the starter generator. The starter generator runs at a really high rpm, not sure what rpm exactly, you would have to figure that out. Every AC generator I ever saw in the IH approved accessories and attachments catalog mounted below the frame in front of the tractor. May have been one oddball that mounted on the side. The pulley on the drive cup on the flywheel end of the engine is cast and machined as part of the engine clutch driver and driveshaft driver. That pulley is pretty small, only thing I've seen driven off it is the hyd lift for gear drive CC's. And no way to turn it off/on, engine runs it turns.
Another possibility would be getting a rear transmission PTO for your 128 and running the generator from that. Runs 515 rpm if I remember right, have to speed it up a lot for 3600 rpm for the generator. My 982 Super Garden tractor has all the options, Cat 0 3-pt, rear 2000 rpm pto, steering brakes, frt aux hyd outlets, 20 hp Onan, it would make a great generator tractor.
Greenfrog
01-27-2020 18:08:55
Mounted to back of motor. No size change here, plus have to disconnect drive shaft to get belt on.
buickanddeere
01-26-2020 07:15:42
Usually that dealer has 7.5Kw ST Generators in stock . Would be a better choice than the 5 Kw pictured .
DR. EVIL
01-25-2020 14:44:25
I'd put the generator on the gear drive, the 128. Put them in neutral and they stay put. My CC Hydro's sometimes tried to sneak away. The PTO clutch pulley is an odd size, 3 and 7/8ths or some such unavailable size. Get the closest size and run your engine just a tiny bit over it's 3600 full load rpm. Get a digital photo tachometer at Harbor Freight or Amazon, $10 to $15 or less. As said, make sure generator can run both directions, or at least the right direction. Might as well get a 5000W generator, use all 12 hp. Your Cubbies both have quick-attach, I've made several attachments to quick mount, or just weld or bolt a mounting plate to the quick attach from your mower mule drive. That's the handiest implement mounting system on any garden tractor.
Greenfrog
01-27-2020 18:06:54
 Re: Generator head for the CC in reply to DR. EVIL, 01-25-2020 14:44:25
Yes, my 129 creeps also. Would have to set brake or block wheels.
buickanddeere
01-25-2020 13:47:02
buickanddeere
01-25-2020 12:55:50
May as well be able to use all the engine s power . Single largest problem with Home, Hobby and Farm generator purchases . The purchaser chooses a generator that is 1/2 the size of what is actually required . Check on eBay for " belt driven generator " and "ST Generator" .
DoubleO7
01-25-2020 10:41:30
Be sure to use a generator head that will work with the engine rotation and the mounting you have in mind.
Bob
01-25-2020 10:59:18
 Re: Generator head for the CC in reply to DoubleO7, 01-25-2020 10:41:30
IMHE, most AC generator "heads" are not rotation-sensitive, but it certainly would be "due diligence" to verify that for the specific unit one wants to use!.
Dusty MI
01-25-2020 07:05:06
That's true if setting throttle while under constant load.
But my loads come and go. So this is the way I set it under no load, and my load is not fussy as to hertz/cycles.
timcasbolt
01-25-2020 05:43:32
That works, and is usually good enough, but it's better to use a cycle counter and adjust the throttle for 60 hertz.
Russ from MN
01-23-2020 19:28:51
I looked at the Northern tool website, and it says horsepower required is only 5, so you could overdrive it a little, and run the engine at a lower rpm, BUT! Then you would have the danger of producing higher voltage and frequency. If you have a meter (kilowatt) and only use it yourself you could do that, but probably shouldn't!
Dusty MI
01-23-2020 18:44:11
You need about 2hp per 1000 watt.
My belt driven generator is a 4000 watt and my 917 Allis garden tractor is 17hp so I belted it so the engine does not need to run full RPM.
I have a volt meter and set the throttle so it puts out about 130 volts.
Dusty
t.r.k.
01-23-2020 18:40:13
I am thinking that back in the day some company offered a front mount generator for a CC. I bet there would be a picture in the 'allied equipment catalog' on IHCUBCADET.COM. finding one might be out of the question.
I am thinking those K-series engines were originally set up to turn about 3200 rpm at wide open throttle. I am thinking that any generator head you get now will want at least 3600 rpm. (Briggs and Stratton specifies 3750 no load for theirs.) So you want to be turning 1.125 faster than the crank pulley, if my math is right.
So if, lets say the pto pulley on the engine is 4", then you want your generator pulley to be about 3.5".
Your actual power generation capacity might be related more to how much torque your belt can transfer than the engine or whatever the generator unit itself can develop.
fred kobs
01-26-2020 05:56:07
 Re: Generator head for the CC in reply to t.r.k., 01-23-2020 18:40:13
I think it was Pincor that made the generator for Cub Cadet. Usually a couple a year come up for sale on the Only Cub Cadet web site.
Bob
01-23-2020 18:36:47
Likely, your GT engine runs 3600 RPM's at full throttle, so the pulley size on the generator would need to be the same size as the one on the engine.
Dusty MI
01-23-2020 14:40:14
I'd send you a picture of one of the ways I use mine, if I could figure out how.
Dusty
Billy Shafer
01-25-2020 11:07:31
 Re: Generator head for the CC in reply to Dusty MI, 01-23-2020 14:40:14
I am staying out of this one for one reason. Lawsuits.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
