Cat 955 h injector pump
Moreland2009
New User
So I just bought a 1960 955h. It had 2 plungers stuck in the injector pump one question is. Is it possible to set the rack with the govenor still attatched. And question 2 can you get it 180 degrees out of time if I pulled the pump off the accessory drive. I know it has the off set tang but was just curious if the pump was turned half a turn if it would still go back on the accessory drive putting it 180 out.. thanks
