Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
Re: Shop air lines
GlenIdaho
01-16-2020 09:27:54
I plumbed my shop using black pipe and discovered that it produces a lot of moisture necessitating a good filter. If you do painting I am sure you know that water is your enemy, same with air tools, not good. I did some reading and the problem with pvc is that it can become brittle over time and fail under high pressure. I also found that copper does not produce the moisture that steel does. If I were to do it again, I would use copper. It is easy to work with. I would make sure that it is not the thing walled stuff they are making now.
Russ from MN
01-16-2020 13:05:27
 Re: Shop air lines in reply to GlenIdaho, 01-16-2020 09:27:54
How does black pipe produce moisture? The moisture is in the air, condenses on the inside of the pipe, the colder the pipe is the more water you get. I would think copper would condense out just as much water as black iron!
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
