Company Logo Shop Now
Tool Talk Discussion Forum
Re: On building a manometer
RCP
01-12-2020 09:24:01
It depends, I would think you want static pressure differential with no velocity effects, in that case you want the tube to have a 90 bend pointed, placed in the center of the flue and pointed towards the exhaust flow.
If that isn't possible you can likely get a good approximation with a straight tube that is 3-4 inches inside the flue.
Rich
mikeb789
01-12-2020 09:52:17
 Re: On building a manometer in reply to RCP, 01-12-2020 09:24:01
A water tube manometer is not going to work for checking the draft in the chimney. You will not be able to see the 2 ends of the water move .02 inches apart in height.
Now, if you want to measure the gas pressure of the gas feeding the burner, you will be able to see about 3 inches of water column for natural gas, or 10 inches wc for propane.
Copyright © 1997-2020 Yesterday's Tractor Co.
