BarnyardEngineering
- Location
- Rochester, NY
In looking for a belt sander/grinder that wouldn't break the bank, I settled on a Made in USA Kalamazoo 2"x48" belt driven vertical belt sander/grinder.
I had this 3/4HP motor laying around from a hay elevator that I bought for parts a couple years ago.
Built a stand, belted it up 1:1 to start with. Runs nice, could probably run a little faster in fact.
I was expecting to be able to "reef" on the material and the motor would just take it, like my Baldor 3/4HP 8" bench grinder. You can't stop that thing.
Nope, I can easily stall the motor sanding on the corner of a 2x4. Not impressed with the power at all. It's better than the old Harbor Freight 4x36 I used to have, but only marginally. I was expecting to be able to shove a 2x4 into the belt and turn it into dust as fast as I fed it in...
Do motors get weak or is it an all or nothing thing? It seems to start fine, runs smooth and quiet, but just has no torque.
I'd buy another motor, probably a 1HP, if I thought it would help.
