Mutt and Jeff
Jack stands
some just crumble under the weight
some never have the right height too short for the job to tall for the jack
Some never have the right base width, get em in place and the jack won't fit between them
some should never ever even be used
some as I lift that ratcheting height release sends the thing flying down on just enough palm skin to pinch to cut it loose or blood blister extreme
some are so heavy it takes a machine to move
some have absolutely no traction against what it's supporting flat polished and greased
remember the ones that had pins we lost
or the pins on chains
the pins and adjusting holes so mangled
using a bolt instead
I just buy more harbor freight floor jacks and use a bunch of those
jack stands
jack stands
