Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
Follow up on CNC
David g
11-09-2019 06:43:19
I completed the CNC mill, but have not used it the last year due to lack of time to work on new designs.
My biggest issue with it before was the customization required going from solidworks to linux CNC. There is a piece in the middle called a post processor that customizes the instructions that Solidworks sends out into usable information for the mill. I used a generic post processor for a FANUC controller that did not work real well. I ended up having to manually fix a lot of the commands. It appears to me most of the issue was that solidworks CAM assumed I had an automatic tool changer, which I do not have.
Janicholson
11-09-2019 12:15:25
 Re: Follow up on CNC in reply to David g, 11-09-2019 06:43:19
I found a LinuxCNC post on line at LinuxCNC Forum. Might help some. T number them M zero six in the form of T6 M06 is the tool change command. Removing those, and any H6 command from following code from a file should prevent errors. 6 is an example of a tool number, not always 6. Jim
Steve@Advance
11-09-2019 07:26:30
Glad you got it going!
The Fanuc controls are very reliable, so reliable I never get a chance to diagnose them.
It's a real nightmare when one does fail, or suspect it failed. Calling Fanuc for help is a ridiculously priced ordeal. They send out the worst tech first, then work up the ladder until someone can actually repair it.
The trainee gets paid the same rate as the real tech...
shoprat
11-10-2019 05:10:54
 Re: Follow up on CNC in reply to Steve@Advance, 11-09-2019 07:26:30
I've nothing but good results with Fanuc technicians.
David g
11-09-2019 09:27:12
I am using the FANUC post processor file, gets it close, but still a lot of manual fix up.
I will customize this file and save as linux CNC and Grizzly.
David g
11-09-2019 09:25:54
This has Linux CNC, you have to configure the post processor file to handle valid commands, and to disregard the others.
Gonna take a lot of research this winter.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
