Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
OBD1 and OBD2 Code readers
michael soldan
11-08-2019 11:14:59
Canadian Tire has a sale on code readers , price ranges from $39 to $299. I am wanting it for a 1995 Mustang but some code readers state they are for 1996 and up vehicles. The 94 , '95 , and '96 V6's were all the same. Dose anyone know if Fords prior to 1995 have plug ins for OBD1 or Obd2 ? Thanks
Tony in Bama
11-13-2019 10:10:48
 Re: OBD1 and OBD2 Code readers in reply to michael soldan, 11-08-2019 11:14:59
I have a 95 GT with a 5.0L, and it's OBD1.
Caryc
11-10-2019 22:40:41
And the thing is that I know the shop that fixed it charged me a lot less than the Ford dealer would have. The shop has also been in business for a lot of years.
Hobo,NC
11-10-2019 18:39:03
Some independents are turning down anything older than 2000. I need to cuzz you can lose your arse on older vehicles.
Everything you touch will bit ya, quality parts are not out there and parts stores no longer stock parts for'em...
If you have found a guy that can diagnosis your 89 hang on to'em they are a dying breed... Scan tool manufactures are not supporting 96 and down and you are going to see 96 to 2000 go by by...
Caryc
11-10-2019 09:50:39
I have an old 1989 Ford Aerostar van that is my "go to Home Depot vehicle. I went out to use it about a year ago and it wouldn't start. I had AAA tow it to the Ford agency here in town and they said we can't work on it. It needs an OBD1 code reader and our equipment won't do it.
Imagine that...a Ford dealer that won't even work on a Ford. I finally found an independent mechanic that had a shop in town who fixed it.
Bruce(OR)
11-09-2019 06:23:26
Generally speaking,
Scan tool generally does not indicate a bad sensor,it shows you the sensor that is not within operational parameters. I stopped pulling wrenches about 16 months ago. Also, ~if~ you get a series of codes, 13, 44 etc, fix the lowest number first. After you made a repair, disconnect the battery to clear the memory, unless the scan tool has the option to clear codes, reconnect and start the engine, drive it if needed and see what comes back, if anything. Generally cheap scan tools will only pull codes, the better ones will give you a data stream and the better ones might let you interact with the computer to give it commands to assist in diagnosis. Raise RPM, delete cylinders, etc. Have fun with your toy.
Bob
11-09-2019 05:42:27
I'm wondering why you don't just look and see which style of diagnostic port your car has?
thepumpguysc
11-09-2019 04:05:26
I've got a 95' Ford Bronco {Full size}
& I have to use the ODB-1
Also when checking the ABS system, the plug is under the hood.. red cap
between the firewall & drivers side. fender.. That's where it is on mine anyway..
4play
11-08-2019 22:03:05
Ford started OBD II in 1994, not all were OBD II until 1996 but most were by 1995, From 1994 the V6 mustangs were OBDII, the V8s (5.0L) were not until 1996 (4.6L). OBDII scanners will work on a 95 mustang V6.
1996 was the year OBD II became mandatory on all US vehicles.
Stephen Newell
11-08-2019 18:40:35
OBD 2 began in 1996 so 1995 would be OBD1. OBD1 isn't very informative. It can just point you in a general direction if your check engine light comes on.
Gambles
11-08-2019 17:01:04
The OBDI and OBDII debate on a 1995 Mustang can be tricky. My first question: Do you have a V8 or a V6 in there? Let's remember one thing: By 1996 all (or almost all) cars were on OBDII. Some cars had it before then. Okay, depending on the exact date your Mustang was manufactured MIGHT play a role in this, but the 1994 and 1995 V6 mustang had the OBDII port. It had the early OBDII system, more like a beta version, but the diagnostic hookups were OBDII. Now the 1994 and 1995 V8 Mustang used the OBDI system. Yea, it was an interesting time in the auto world. For the most part, you can use an OBDII on a V6 1995 Mustang. If you have the V8 in there, expect to connect an OBDI diagnostic machine to it.
The tractor vet
11-08-2019 16:06:49
On the older Fords one could get by with a test lite on one of the terminals in the test block. Been years since i have had a Ford , so a little vague on them anymore since i went with a Goat .
Hobo,NC
11-08-2019 15:35:47
The more I think about it you may have to have them both.. I remember having to jump from one to another to do self test...
Hobo,NC
11-08-2019 15:32:15
My scan tool says use OBD2 cable.
John M
11-08-2019 13:27:45
Here ya go.....
John M
11-08-2019 13:31:08
 Re: OBD1 and OBD2 Code readers in reply to John M, 11-08-2019 13:27:45
My bad - I didnt realize the pics were blurred out. Heres a video.
Hobo,NC
11-08-2019 11:56:57
Post the first 10 digits of the vin # I will punch it into my scanner some 95's had a obd2 connector...
I would suspect if it says 96 it will not go back to 95 : (...
michael soldan
11-08-2019 12:18:20
 Re: OBD1 and OBD2 Code readers in reply to Hobo,NC, 11-08-2019 11:56:57
1FALP4448SF209702 . This Mustang could be OBD1 and the scanner I am looking at is OBD1 and OBD2 ..not 100% Thanks for your help
bjb in Tx from Ne
11-08-2019 11:19:25
If you have or plan to have any GM vehicle, make sure you get the model capable of reading those codes (OBD2)...
Copyright © 1997-2020 Yesterday's Tractor Co.
