hunterguy92
Hello all,
I?m currently at a standstill trying to separate the engine from the rest
of the tractor.
To start things off, yes I have removed the starter and the bolt behind
it as well as the front bolster and both frame rails (10 bolts total). The
problem seems to be that the alignment studs are holding up my
separation. I?ve tried PB blaster over the past few days and have hit
them with a propane torch as well, but still no movement around the
studs.
Anyone have any advice on splitting this old iron?
Thank you!
of the tractor.
studs.
Thank you!
