Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
Hammer I.D.
Butch(oh)
08-13-2019 17:21:35
What was this hammer used for?
Cliff(VA)
08-15-2019 09:28:00
 Re: Hammer I.D. in reply to Butch(oh), 08-13-2019 17:21:35
That is NOT a hammer. Whoever called it a cold cut is correct. It is a handled cold chisel. It is a very common blacksmith tool.
Cliff(VA) now (NC)
PJH
08-14-2019 15:35:27
My friend, a railroad section hand, has a tool very similar to that. He calls it a "cold cut". He said it was used to "mark" the sharp corners all around a railroad rail, then the rail was put in side tension and snapped to length. One man held the cold cut, while another man struck it with a heavy sledge. I can't imagine that working, but I never knew him to tell phony stories. I have one around here somewhere that I used to try to use as a firewood maul. It did not work well for splitting wood - just a little too light weight for my liking.
Butch(oh)
08-14-2019 03:16:25
I inherited it from my step father. I don't know if it helps or is even related to it but he was a pipeline welder for the gas company. I'm just going to clean it up a bit and let it occupy a spot on the hearth with my other old axes and hammers.
Russ from MN
08-13-2019 20:38:43
This is a Rail spike hammer, I even drove a spike with one once!
tony in sd
08-14-2019 04:08:14
 Re: Hammer I.D. in reply to Russ from MN, 08-13-2019 20:38:43
Itís not a spike maul. I drove 1000ís of spikes with a spoke maul (above) when I worked for the railroad one summer in my college years. We shortened the handle so we could swing it faster. 3 hits was all we needed to set the spike firmly.
Butch(oh)
08-14-2019 03:07:16
Around the steel mill they called that type of spike sledge a "B&O"
NC wayne
08-13-2019 20:34:20
I've got hammers designed to drive spikes that I use to drive pins, or as a handled punch when I need a heavier sledge to do the driving. This definitely isn't one
I'd also say this one was used as a chisel. I say this because if you look closely at the head, it appears the edges are slightly mushroomed. Mushrooming tends to happen far more from being struck with another hammer, rather than being used to strike something.
Absent Minded Farmer
08-13-2019 19:00:03
I had also thought it was a spiking maul until I seen the flat wedge on the right. Handle's also too short for that & the hammer end is too fat. x3 on the hot chisel.
Mike
unc
08-13-2019 18:28:11
X2 hot chisel. unc
Jeffcat
08-13-2019 18:01:59
The axe used for splitting rails looks something like that but with a nice sharp end. Lots of tools are just different versions of a more basic tool and then modified to do specific jobs. Really neat to see how tools of long ago have changed.
John Garner
08-13-2019 17:52:32
Looks like a blacksmith's "hot chisel", used to cut red hot metal. A blacksmith's chisel has a handle -- used to hold the chisel edge against the piece to be cut -- and then struck with a hand sledge. The blade of a hot chisel is substantially thinner than the blade of a cold chisel, and the hot metal is much easier to cut than cold metal . . . those two factors together make a hot-chisel cut very much easier than a cold chisel cut of the same material.
Steve Neul
08-13-2019 17:29:10
I would call that a rail splitter for driving railroad spikes.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
