Aluminum welding rod
DRussell
I bought a Century five star AC DC welder with a high frequency arc stabilizer off of Craigslist a few years ago. It came with this package of aluminum welding rod. Someone wrote AC Aluminum on the package. I can weld better with it on DCEP than on AC. Does anyone know what kind of rod this is? I included a picture of a weld I did with it. Don't judge too harshly. The slot for the tailgate chain on my bed was broken at the bottom and the back and I welded it back in place using this rod.
Hello drussell,
You did good! Aluminum stick rods are a joke. They usually are AC rods though. You can laugh at my weld. 3/32 6013, welded with a Montgomery Ward buzz box, about an hour ago, I changed the heat on the long run. Boy do I need to practice!
Guido.
I used some similar rod to do repairs to aluminum casting. It was the filler rod for a tig. Every trip to the plate is not a home run? I did no better.
The high frequency stabilizer makes a world of difference. Much easier to get the arc going with it.
I bought some aluminum rod once never could get it to strike or do anything it would Spark a little bit but that was it maybe I was trying run the wrong polarity ? Didn?t matter all I had was an ac welder anyway so I ended up taking the part to town and getting it welded right
You done good. That is a very difficult electrode to use. A couple of tiny suggestions- warm up the rods before use to drive off any moisture, and preheat the material to be welded if you can. Good job. unc
I ended up with a glob when I tried it. Had a hard time just moving the rod down fast enough much less moving it sideways to lay a bead.
If it breaks again I know the guy who welded it this time. I'm pretty sure he'll weld it again. :)
I believe aluminum rod is recommended to run on AC because you get the cleaning action on AC current. I couldn't get a stable arc on AC, but could go right along on DC. DC gives you a stable current and you get the cleaning action with the electrode on positive.
Thanks. I started out about 110 amps on DCEP, but that was burning away too much base material. Dropped down to about 80 amps to finish.
I've often wondered how it would work to feed it with argon from a wire feed welder while using the stick rod. I've got a little wire feed welder which doesn't produce enough amps to weld anything thicker than 1/16" but I do have a larger stick welder that would.
Tried them a few times over the years and have come to the conclusion
that their best use is to bend the ends and use them for hanging things
while spray painting.
I get along pretty nice welding al with dc mig.
Brad
