Stephen Newell
I have a front wheel drive oldsmobile I've been trying to do a compression test on. I had one tester which broke on me before I could complete the task. Today I bought a new one and read the instructions on it and it said to run the car until it get to it's running temperature, pull all the plugs and preform the test. Now with this car there is so little room it takes all day to do six cylinders and I can't picture trying to do it on a hot engine. To me it seems completely impossible to hook up the tester on half the cylinders hot without completely burning all the skin off your hands. Besides that two of them takes hours each to connect on a cold engine. I believe the engine would cool off before the tester could possibly be connected. There is no way to use some kind of heat resistant gloves. Any idea how I could preform the test.
Background on the vehicle it's a 87 Delta 88 which the timing gear went bad. That has been fixed but I believe either some of the valves have been bent or perhaps stuck. I'm getting a putt putt noise at the exhaust so I held a piece of paper over the exhaust pipe and it sucks the paper in and out fluttering. I'm just trying to make sure a valve job is really necessary. The car had sat for three years and I may try to use some penetrating oil on the stuck valves and see if that works first.
