Battery isilaters
To any one who is , or has knowledge of ""electronics""
I looked on line to find diagrams on how to construct a battery isilater, the only thing I waas able to find clearly was the information on what diods to use. No where didn Infind a diagram on assembly or on installing it in the circut between bateries.
Can any oune assistme in the two diagrams. I think it would be less expensive to hand make the unit that to purchase one off the shelf.
You may e mail me direct if you are able to assist me.
Thank you
Wm.
A "Battery Isolator" can be no more then a simple DIODE which is a one way current flow check valve. If connected between two batteries it could be configured so current can flow FROM battery A TO Battery B, BUT it wont allow B to draw current from A........ Such may be between an RV engine battery (A) and its house batteries (B) so the engines alternator can deliver some charging current to BOTH via the A to B Diode BUT when parked the House battery B cant run down the engine A battery (no current flow B to A)??..The diode needs to have sufficient current rating and voltage rating for the system. There will be a PN Junction Voltage drop across the diode.
Another isolation method for battery B is a mechanical isolation relay. It looks like a Ford starter solenoid BUT has a 100% duty cycle rating. Battery A and B are on the two studs and the relay closes connecting them together when energized but opens and they are separate (B is isolated) otherwise.
They also make solid state isolators with terminals for Battery A and B and another to an alternator.
If you stick a diode between two batteries wired at the right polarity current can flow one way but not the other, that's a cheap simple form of isolation
DISCLAIMER I had to do this in a hurry its not perfect nor exact nor intended to be, I have to get a Warranty Deed and POA finished for a client...??...Im just "semi retired" the months I'm in my sticks n bricks home off the road lol maybe someone not so busy can draw you a diagram, back to work for me
John T
PS Grrrrrrrrrrrrr My Bad, told you I was in a hurry, think I may have my A and B terminology mixed up...A can flow to B BUT A cant draw current out of B...??.THATS HOW AN ALTERNATOR CAN CHARGE ENGINE AND HOUSE BATTERY BUT HOUSE BATERY CANT RUN DOWN ENGINE BATTERY WHEN PARKED
I apologize (too big a hurry) so don't anyone have a calf now lol that's my first mistake today
John T
Diodes use between 0.6 to 0.7v. So the isolated battery won't get fully charged. Use a relay if you want full voltage. Turn relay on when alternator is changing
What do you want to isolate? For most uses I can think of, a relay is MUCH better then a rectifier-based isolator. Rectifier-isolators always cause a voltage drop/loss and can blow like a fuse (and then not work at all).
A continuous-duty isolation relay costs around $20. If you want to avoid the wiring needing to energize the relay, an extra $40 to the relay and it can work automatically by sensing voltage.
RVs are a common place to find isolaors of both types (rectifier and relay). Many auto/truck makers install them OEM and all I have seen are relays. I have never yet seen a rectifier-based isolator on a new car or truck (but I have not seen them all). Motorhomes yes, because they are cheap to install.
I should of mentioned that if you use a rectifier/diode to limit electric flow to only one direction - you have to know the max amps that will ever flow through it. They are rated by max voltage and max amperage and blow fast if you exceed the limits. I don't know if you are working with a high-amp charge circuit? Or just a low amp alternator field-circuit? Field circuits like on Delco 10SI alternators do fine with single diodes rated 32 volts and 10 amps. They only cost a buck.
If I repeated some things that have already been posted - not done because I am an idiot. Just in a hurry and did not read every word in every post.
look up blue sea (ACR) automatic charging relay i put one in my boat with two batteries it separates one when it drops below 12 volts so your start batt stays charged , when started back up both go into charging again , look on amazon
Im much more a fan of a mechanical isolation relay then the diode types. They are relatively cheap and easy to install. Of course they can develop a voltage drop due to burned pitted carboned contacts which may be more or less then the 0.6 PN Junction drop. A battery can still receive some degree of charge even with an inline series voltage drop but Id prefer there be none or as little as possible.
John T
John,
I charge my dump trailer batteries, 2 in parallel, with a direct connection via the plug. It takes a lot of current to charge my 2 batteries. I wouldn't want a 0.6v drop using a diode. Not to mention buying a diode large enough to handle the current I use would cost a pant load.
I use 30 amp circuit breakers. They will reset after they cool down.
(quoted from post at 06:42:36 05/25/19) John,
I built one years ago like John described . I used some 50 amp diodes that were stud mounted. The hi-amp diodes need to be heat sinked.
j
If you really just want a diode/rectifier that can handle some charge current for isolation? One easy way to do it is just use a pre-assembled "isolation diode" like John Deere used on tractors, and American Motors used on cars.
Single rated at 35 amps for $10, and double rated at 60 amps for $20. Having it already mounted in a steel plate makes it easy to retrofit.
Here is a suggested isolation system from Delco Remy. Often used on motorhomes and trucks with electric lift gates. Again, I have no idea what it is you are trying to do. It is all about amps. No diode is going to handle a high amp rate in the hundreds.
Thank You for all your suggestions and information I Like then 12 v isilater with diod trip"
will look up item locally in London Ont., where we live.
Wm.
Use a 60 or 100 amp 12V relay from Princess Auto and an engine oil pressure switch .
No voltage drop and the auxiliary load can not drain the starting battery.
