Lawn sweeper?
I'm looking for the biggest lawn sweeper
that work at slow speed. My back doesn't
like bouncing at the speed needed to
throw the grass to the back of the
hopper.
I don't like using a bagger or vac wagon.
Both require a shower after using.
So what is the best low speed lawn
sweeper? Does anyone make a sweeper with
a motor?
I think I responded to one of your earlier sweeper posts. Case or later Ingersoll. No longer made but parts are readily available. Find an older one and repair as needed. two brush design. First, bottom brush picks up the debris, second top brush throws it forward, not . The hopper is between the towing mower and the drive wheels. The weight of clippings increases traction. The wheels/tires are much bigger than any similar sweeper.
example:
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=201759
https://harperturfequipment.com/turf-vacs/tv40/
http://www.smithco.com/golf-course-maintenance/sweepers/sweep-star-v72-e-engine-drive-big-vac/
Thanks, what you posted is a little bigger than I'm looking for.
I do have a 9 hp argi-vac but don't want to use it because I'll need a shower after using it. Not to mention all the dust it suck fills my lungs and eyes. I also have a bagger for back of mower. It's dirty too.
Looking for the biggest sweeper that works at low speeds for my back.
I've never seen a sweeper that is pulled backwards. Any idea how well it works?
I may have asked about sweepers in past. This time I need one that works at slower speed. Possibly a sweeper with a small motor on it. Nothing golf course size.
I just pull a 54 inch lawn sweep seems work fine, I have also hooked my 42" and pulled in tandem works okay. you can get parker units pull up to three or four at time.
Best sweeper I've ever used. built like a tank. I have had Agrifab and brinly. The case is far better.
You gave me an idea of putting two hitches on back of woods mower to pull two lawn sweepers. Jubilee bounces less than a riding mower. So after I'm finished mowing, I'll pull lawn sweepers and pick up hay I put in a windrow while mowing.
