Coleman Powermate 4000 Revisited
DonNOhio
I picked up the generator this afternoon. It has a Briggs engine, which is good. Definitely low tec. Pull start, and two outlets each for 120 & 240. 4000 watts surge, 3600 running. It will serve my needs.
Thanks again for the input.
These are the parts manual for the Onan units. They might give you a source for parts. Out of production but it may give you some help. Go to Smokstak or Twinslan Onan manuals.
919-0220
919-0309
Used very little.Elderly gent had it in his garage and asked the neighbor to sell it as he was unable to start it any longer. The only thing I see it needs is a fuel shut off, leaks a bit. Tightened the packing to no avail. I am going to put a better muffler on it as it is rather loud. Maybe a bigger gas tank too.
Thanks Billy for the parts reference.
I have a 4000 and a 5000, both with Briggs & Stratton engines. Generators have been flawless for years. Just noisy. I put extra mufflers on them and it helped a lot.
Looks as if you got a very nice deal. Good find. Give it a wax job. By the way you can get quiet run muffers that are made for generators. If you can do a little cobling get a quiet run muffler and hook it up. They make a Big difference. Take a look on Ebay at number. 253848673410. I mounted one like that muffler on a big generator I had. Staggering difference.
Had to chuckle when I saw your car muffler. Thought people might be puzzled if I told them to go junk yarding and pick up the muffler from a Pinto. They were a perfect small oval muffler and were great for hack jobs like this. The Pinto had that little 4 cylinder engine and didn't need that big of a muffler. Ahhh the good old days.
Several years ago I had a Onan out of a RV. I added a farm tractor muffler and gas tank to it. It would run quiet and about 15 or 16 hours on 10 gal. I was thinking of using a Farmall Cub muffler. I need to go to Glenn's Surplus in Shelby O. and shop around. They have a lot of lawn tractor and mower parts.
My parents bought one just like that right before Hugo came through NC. Was that '89? We kept it going steady for 9 days while the power was out, running freezers and refrigerators at three houses. We would run a tankfull out at our house, haul it to Grandmother's, hook up, run a tank full through it, go to Aunt Lib's, and do the same.
I have another much newer generator, but I bet that one will be the one that starts when I need it.
I think you will get good service from it.
Its loud though.
