Source for bleed off valve on a fuel pressure test gauge
wsmm
I know I can buy a whole assembly with the fuel bleed off hose, hose from gauge to schrader valve on fuel rail or adapter. I already have everything except for the fitting that attaches to the "T" and is used to bleed of the pressure and fuel when you're done testing. It runs $13.00 and I think the release valve alone just might be cheaper
View of Actron hose with pressure and fuel bleed function
