Hydraulic pump
Anyone one know where to find a rebuild kit or at least gaskets for this log splitter pump? J.S.Barnes begat Haldex which begat Concentric. Not sure if x m means model.
After milling the end plates flat and cutting the sides of the gears flat . Then narrowing the Center section to regain the clearances . The pump was assembled with varnish as a gasket .
