Home made tools
I tried to get in contact with John Smith to get the input shaft to my SOS repaired the Smith way. I never got a response so I set out to do it myself. I bought a Harbour Freight 5" bench grinder and mounted it up-side-down on my lathe and surface ground the hex into the end of the shaft.
I welded a 1/4” plate to support the grinder and used the stud in the front to bend the plate in the back to take really small cuts. I am amazed it came out to within 0.0015" flat and parallel on all 6 sides. The socket fits almost too tight.
The headstock gears all had odd numbers teeth so I had to index the part using something else. So, I wrapped apiece of duct tape on the headstock drum, marked where it overlapped and cut it to length. I took it off the drum, laid it on the work bench and marked it with 6 lines. I wrapped it back on the drum and used a fine scale to line up the flats. Don't look too close at the welding, it is terrible.
Good work, Catalina. Necessity is the mother of invention. It's nice to have all the tooling you need, but sometimes you still have to use what you got. I once ground a specialty reamer using a Dremel tool mounted to the compound. It wasn't fast, but the job was successful, and the customer was happy. unc
Stephen, I have a complete tool post grinder and a partial which could be made to work. What do you consider too expensive?
VERY impressive!!
Don't think I could have thought that up, even when my mind was working its best. Course, the only "welder" we had was a small spot welder. *lol*
Nice job! I have a tool post grinder my Dad made for our little 6" Atlas. A little 3" stone on a home made mandrel on a bent flat stock base driven by a little sewing machine motor and belted with a big O ring. Works okay for what it is!
(quoted from post at 12:45:01 01/19/19) Cover your ways and make sure you keep all grinding dust out of your lathe.
I kept it covered up the whole time. After I was done grinding, I cleaned and oil it up completely.
