Winch solenoid diagram
TrucknLoaded
New User
Hi! Anyone here who has a warn winch? Is the generic diagram of how the solenoids are hooked up to reverse the motor the same with the warn winches? I assume they'd all be pretty much the same. Hope someone would confirm. I've tried to look for specific but haven't found one on the website
warn
Type in to Google warn winch 8274_wiring diagram, the search brings up a few easy to uderstand wiring diagrams. It should work with any 3pole DC motor.
Warn Winch is a few miles away. I stopped in once and the speech I got was the solenoids they run are a heavier duty that the typical Ford solenoid.
I suspect they may be the same as the ones running on diesel glow plug systems. Ford 7.3 pre '94 come to mind.
As for wiring them, I just did a search on "warn winch solenoid wiring diagram" and got good results.
The link might also do it for you.
Untitled URL Link
