What is it.
krm
What is this tool used for?
It's on the order of a tool to remove the snap ring on a Delco starter armature holding the drive on, although it can be done faster with a little Snap On pliers, small screwdriver and two bigger pliers to pinch the pieces back together.
I think I am going with Gab and the Case Guy, it is just like the one in Gabs picture. Thanks for all your help. I could use a brand name and # if you can make it out on the ones you have.
(quoted from post at 00:13:10 11/11/18) I think I am going with Gab and the Case Guy, it is just like the one in Gabs picture. Thanks for all your help. I could use a brand name and # if you can make it out on the ones you have.
Blue Point GA188
Yep I have only seen one in action at a starter repair shop I spec not many are in captivity most of us just fight the clip on/off... I would use a paint marker mark it so my Kids could get $25.00 for it when I meet my maker...
