Company Logo Shop Now
TractorLinks.com
Tool Talk Discussion Forum
Proprer way to do a leak down test on a 2 cycle engine?
wsmm
11-08-2018 16:30:02
What is the proper way to do a leak down test on a 2 cycle engine. What pressure would you use.
Geo-TH,In
11-09-2018 03:53:34
 Re: Proprer way to do a leak down test on a 2 cycle engine? in reply to wsmm, 11-08-2018 16:30:02
wsmm,
I had the spark plug on one cylinder of a kohler command that would carbon up. I bought a leak down test kit. Both good and bad cylinder showed good. Compression test on both cylinders showed the same.
I pulled the head off bad cylinder, ground the valves, and solved the problem.
I have little confidence in a leak down test.
t.r.k.
11-08-2018 17:56:18
Block off intake and exhaust, and pulse port to carburetor if it has one, pressurize crankcase, My only specs are from a Husqvarna manual, pressurize to 10 psi, should not leak below 7 psi in a minute.
Someone on here a while back said to also test with 10" vacuum. I would guess it should not go below 7" in a minute. They were saying some seals leak air in but not out.
David G
11-08-2018 19:11:26
 Re: Proprer way to do a leak down test on a 2 cycle engine? in reply to t.r.k., 11-08-2018 17:56:18
10" of vacuum is about 5 PSI, 7" about 3.5 PSI
