Angle Iron
I was looking at a friends 046 saw. It was given to him through a friends father. He couldn't get it to start. Pulled the plug it has fire but weak, dribble a little gas in the carb after putting the plug back. Nothing after 8-10 pulls. Pulled the plug replaced it with a known good plug shows great spark. Dribble a little gas in the plug hole. Not so much as a puff. Pulled the recoil starter and put a half inch drill motor on it no love. The drill was spinning it pretty fast but the decompression button never came back up. I had not used it when trying to start before. Fast forward today got my compression tester out, it had been hiding for a while. Compression release activated it has around 50 PSI deactivated around 70 PSI. Any one have a ballpark number on what a good running 046 should be. I had read before that a compression test is hard to do on small engines but still wondering. I pulled the muffler to look at the cylinder and the piston. Not pretty, some deep score marks on the piston as well as the jug walls. I think it has lost so much compression that it will not fire what say you.
