looking for used fillrite 15GPM model 1200C for parts
sanicki
New User
Any one have a used potentially none working fillrite 15GPM 12V 1/4HP model 1200C pump they are willing to scrap for parts? Looking for the main steel tube with the permanent magnets that surrounds the motor armature. Unfortunately separating the pump to replace the brushes cracked the magnets in mine and tuthill no longer sells these parts.
How bad are the magnets broken?
If you have all the pieces, try reassembling it with JB Weld. They will have to fit perfectly, nothing holding them up off the case.
Nothing to loose by trying...
(quoted from post at 17:34:50 10/15/18) How bad are the magnets broken?
hat will NOT work, as at every break a N-S pole is established, and that is a fact. Has time, glue, frustration of failed attempt to loose. Try various suppliers/sellers of Tuthil, as some may have the old parts. I found mine that way.
(quoted from post at 18:49:41 10/15/18)
exactly which is why I am on the hunt. thanks for the reply
they all fall off clean them up and glue them back in place have 5 of them and all fell off over time
(quoted from post at 21:01:49 10/16/18) they all fall off clean them up and glue them back in place have 5 of them and all fell off over time
cant glue back what's broken hence why I am looking for parts.
The 12 volt fresh water pump in our motor home started sounding strange, so I took it apart, and found that the magnets had come loose. I glued them back in place with construction adhesive. It worked fine after that.
(quoted from post at 08:13:02 10/17/18)
Loose" is NOT BROKEN apart.
(quoted from post at 17:57:44 10/15/18) Any one have a used potentially none working fillrite 15GPM 12V 1/4HP model 1200C pump they are willing to scrap for parts? Looking for the main steel tube with the permanent magnets that surrounds the motor armature. Unfortunately separating the pump to replace the brushes cracked the magnets in mine and tuthill no longer sells these parts.
any others with ideas to obtain used magnets? custom magnet replacement cost prohibitive
