Eagle Beagle
I have a gearbox with a 56tc face mount for an electric motor with a 5/8th inch bore on the input shaft. I need to find an adapter so I can use a larger motor ( 2 hp ) with a 7/8th inch shaft.
I know 56tc and 145tc use the same bolt pattern but every 2 or 3 hp. motor has a 7/8th inch shaft. A 184 frame size to a 56 would also work.
Anyone ever seen an adapter like that? It would have to be two pieces, the spacer and the coupling or stub shaft.
Thank's
Beagle
Thank's
Beagle
