Tire Chucks
OliLt
Is there a clip-on or lock-on tire chuck that actually works, The clip-on ball foot chucks and straight line chucks (Euro-style) that I have are hard to get seated or slip off once attached. They both attach and release with a simple lever on the side. Are the threaded tire chucks still around? Thanks for your input.
Here ya go . It has threads that lock to the valve stem when you push it on you push it at angle a little and the the threads on the tire chuck lock onto the threads on the valve stem no clips that don?t work
Untitled URL Link
The best one I have found are AIRTEC brand part number H-5265-OP. They lock on three sides of the stem. You slide it on the stem and then push the outside ring forward to lock the chuck on. They are around $25.
