I've had this charger quite some time and it just started putting out 11.6v when on 12 setting, 7.8v on 6v setting.
I removed the cover to check connections and nothing looked too bad that I could see. Thinking the range switch might be bad I bypassed and connected direct with jumpers. Output voltages remained the same.
Probably not worth fixing but thought I check here for a possible easy fix.
