Quick question, guys!
I've just bought a tractor with a front end loader which will lift 3,300 pounds at the pivot points. Since I'll be using this almost exclusively for industrial use, I now need a set of forklift forks for it, which I'm planning to build myself.
The plan is to build a "frame" that attaches to the front of the loader and have it setup so that the forks have a large bushing on the tops of them, which will slide across a stout pipe allowing them to adjust their width.
Looking around for the forks themselves, prices often hit ~$500 for a set, which isnt really something I consider a decent buy.
Therefor, I'm wanting to build my own.
1) How much would a set of 40" forks, made from 2x4x.250 mild steel hold? I dont want to underbuild this, especially for the application
2) Should I just use 1x3 solid bar stock for this? It would be heavy, expensive, and I'd probably never use the leftovers, but if thats what it takes, then that's what it takes I guess
3) I understand the hardest part of this design will be the 90 degree bend in the back of the fork. I'm planning to run the forks under the loader bracket and reverse-gusset them, assuming the design of the loader will allow it.
Does any of this sound workable? Bonus points if anyone can link me to any references I can use in the future for calculating what type and thickness of material I should use for future projects. Thanks in advance guys!
>inb4 "hurdurdur you shouldn't build this the sky is going to fall" posts
