This is how to do a draw test on a vehicle. Sorry its kind of long post. I hope this helps someone.
1) You need to build this. All these parts can be gotten at any parts store. I got all of then at Fleet Farm. I drilled and tap a hole the size of the battery bolt. You can us it on both type of batteries. Top and side post.
2) You need a digital meter. The one on the left is a $30.00 sears and on the right $400.00 fluke. Both meters will work.
3) Connect your test tool to the battery. It does not matter what side of the battery you connect to. Post or Neg will work the same.
4) Make sure the knob is tight. Start the vehicle and operate all the acc. windows, locks, lights, radio, hvac, seat switchs etc. Then turn the vehicle off and remove the key.
5) Connect the meter and set to 10 amp scale.
6) Open the tester and check the meter. If less than 1 amp tighten the tester and set the meter to mil amps. Open the tester and check the meter. The reading on the meter is the draw on the system. If above 50 mil amps you have draw that need repair. You start on the 10 amp scale so you don't blow the fuse in the meter.
7) The reading on the meter shows 299 mil amps. Start dia. Pull one fuse at a time. If the meter drops you found the circuit with the draw. If not install the fuse and go to the next one.
Found the under hood lamp on. Disable the lamp and the draw goes to 7 mil amps.
Note: If the vehicle is older you can start dia as soon as key off a meter connected. If vehicle has a Body control module you need to what 25 min. for the modules to power down before you start or you will miss dia.
I hope this helps some one. David
