Yard Roller Project
Hobo,NC
Location
Sanford, NC
I have wanted to build a yard roller for quite awhile. I have a 6”X30” water drum (yes I know its galvanized and the dangers welding on it). I have a 2 ¼” pipe I can fit all the way thru it and thinking of making a rectangular frame to surround it… My question am I on the right track putting a pipe thru the drum I would like to use the scrap I have on hand…
If your frame is tube then I would weld a hat shaped
piece or a tube to each end of the tank to bolt a
bearing to then attach a shaft to the tube frame and
into the bearing. Keep it tight between the bearing
and frame and you won't need a large shaft, 1 1/2"
would be good. That way you don't have to worry bout
water tight. Don't forget to drain it in the winter
if you are where it freezes. I have seen lots of
them the way you describe tho and they work fine
too.
Plug all the holes. Put a plug in the end where u can fill it water
and when u r don can drain if. Or center a shaft and fill it with
concrete. Just an ideal
HOBO,
What are you doing off the ford sight?:) Just kidding.
Here is the mother of lawn rollers. I made it using 10 inch moble home I beam, a 500 gallon oil durm, spindles from a madza for bearings, and about 4500 pounds of concrete and re-bar. It's hollow inside and can hold about 250 gallons of water. Empty it weighs in at 4700#. It's 5 ft and change wide. That's about 1000#/ft. If you think about it, you don't want much less. Drive a truck on the yard and you are putting 5000# on 4 tires that are not nearly 5 ft wide total.
Most of my yards are level. You don't want to get this on a steep hill or near water.
I use my roller in the spring when the frost leaves and after a good rain. In the dry summer, forget it, you won't do much good.
I have a 30 gallon water heater roller filled with concrete, not nearly enough weight. If you make a roller out of a water heater, put a box on top of the roller so you can add weight. However, if you think a lawn tractor will pull it, better have bar tires and wheel weights.
George
To save draining the water before freezing weather , fill it with used oil .You never need to drain it. clint
you could roll the ruts out of a blacktop road with that!!!! Iv got to get back on the electric atv plan Just to hot now I work better with a coat in fall winter than sweat dripping off m
Bill, if you put white rock on concrete, it will reduce it to power. Guess I could make AG lime. My tree trimmer got stuck and his bucket truck went all to the axle. Wrecker made ruts too. I was able to work most of those ruts out with just a little dirt and a lot or rolling.
George
Hobo--that's what I did on the one I made 10+ years ago and it's held up fine. It was built entirely from whatever scrap I had on hand at the time, so it's no beauty queen but it does what I made it to do. I also built a frame for additional weight on top--often supplied in the form of a hefty friend or two riding on it, or (more usually) my hefty self riding on it while my friends drive the tractor! This is the only photo I could find easily, but if you want more details I'll see what I can do.
I made a roller just like you are proposing years ago. I took one end of barrel out and flipped it over so both ends look the same. Pipe thru the center and welded it up and it even holds water.
Years ago, my neighbor made a roller out of a 30 gallon water heater tank. He put a seat on the roller for his wife to ride on, 300+#. That was a kodak moment.
30 gallons of water = 250#
estimate tank and metal = 50#
wife = 300#
total = 600#
That's only 200 # per linear foot. Unless you have very soft ground it will be lucky to flatten a mole hill.
George
Well, as luck would have it, mole hills are mainly what I'm flattening, and I've been doing it with that roller for 10+ years now with no problems.
First days work,,, one end plug came out with a air chisel the other I had to bust out with the chisel.. I spend 1/2 a day making bushings to adapt the FWD hubs ( 1985 dodge Omni I don't think their are anymore in captivity) to the drum and axle. Then made the plates and made a run to the bolt store... After supper welded it all together,, Other than getting the other plugs out it should be all down hill from here.... I am $40 into it at this point....
