Owen Aaland
I was testing an alternator I had rebuilt on my Allen test stand. I had it running full load at 72 amp when I had a capacitor that let the smoke out. I managed to get the resulting fire out without any noticeable damage to any of the wires inside. Between the noise, the smoke, and the resulting fire it can sure get a persons attention! I've still got some cleaning up to do inside the machine, little pieces of aluminum film all over the inside of the cabinet.
My question has to do with getting a replacement capacitor. This tester as made in the late forties and the only reference I have found for the company that made the capacitor, THE CAPACITRON COMPANY, Chicago Illinois, is in a museum. Fortunately there is printing on the case that is still readable. (I wanted to take a picture but when I went to use the camera the battery was dead.)
On the case it has the UL listing mark then next to that 2929. A little to the right is marked A1261 which I figured is the part number. Below that is 2.MFD and then 220 V. A.C.
I've ben told in the past that as long as I keep the capacity the same I can substitute a unit with a higher voltage rating. If that is true could I use this one as a replacement?
http://www.surpluscenter.com/item.asp?item=22-1300&catname=electric
The original capacitor is round, 2" diameter, 2-1/4" tall.
