One summer, few years ago we had a power outage. One can get by for several hours without power, so I don't worry very much when the power goes off. We live out in the country.
I learned that it was going to be off for 2 to 3 days. So I got our small motor home out that has a 4000 watt Owen generator on it.
I wanted 3 things to run.
Refrigerator medium size
Water pump 1/3 hp 120 volt
Water heater LP power burner, much like an oil fired furnace, less than 2 amp.
I removed the wires from the breakers that feed the refrigerator and the water pump, and tailed them out and put them on a male cord cap. and ran a neutral from that cord cap to the neutral bar in the panel. Then it into an extension cord from the the running generator. The pump started up, I went up stairs and the refrigerator was running. Good, all was well.
The water heater has a cord on it that just plugs into a receptacle, but I needed a short extension cord to reach the cord from the generator.
When I got back to the basement with a short extension cord, the water pump had come up to pressure and had shut off, but the refrigerator was still running. I plugged the water heater in, and the generator shut down.
The pump and refrigerator would run together.
The pump and water heater would run together.
But the refrigerator and water heater would not, it was not an over load for them to run together, the water heater is a very small load. Much smaller than the water pump.
John, my question is, why would the refrigerator and water heater not run together ?
The generator was built in 2002.
Thanks,
Dusty
Thanks,
Dusty
