Greg Wolodkin
Getting ready to invest in a torch set. Looking at the Smith torches, which are still made in the US, and thinking that the medium duty set will probably be plenty to get me started. Mostly I'll use it for hardening and tempering larger parts (gunsmithing and tool making), heating and "tweaking" larger forged parts (blacksmithing, period reproduction hinges, etc), and more recently tractor repair including heating stuck parts, maybe welding sheet metal, and as I get better with it some of the more typical "blue wrench" jobs.
One of the tips I've used in the past when I was learning blacksmithing was a rosebud tip, and it was very useful for heating larger pieces quickly in order to tweak them. But in looking at the Smith torches and the sizes of acetylene tanks recommended locally, I'm a little confused and I was hoping this forum had some advice.
The kit I'm looking at has the Smith WH100 handle and the MT603 heating tip, which is stated as using 28 SCFH of acetylene. If I do the math right so as not to draw more than 1/7 of the tank per hour, I'd need at least 196 CF of acetylene, right?
The largest tank my local supplier lists for typical use is 145 CF and it's a pretty big tank, paired with a 250 CF oxygen tank. I need to go back during the week and talk with one of the guys at the shop.. I suspect I'll get better info than I did on Saturday with the weekend help. But it seems like that tank isn't big enough for that tip.
I wondered what other folks were using for rosebud tips (or just for heating stuck parts in general) and what size tanks you're using. I've got plenty of space for storage, but I'd like to be able to roll the cart around the shop and even outside depending on the project.
Thanks in advance for any advice!
Greg
Greg
