I AM NEW TO THE SITE BUT NOT NEW TO REPAIRING TRACTORS OR VEHICLES. I OWN 2 300U'S, JUST HAD INDEPENDENT PTO BANDS RELINED ON ONE. AFTER PUTTING UNIT ON TRACTOR AND REFILLING THE REAR DIFF AND TRANS, IS WAS LETTING THE TRACTOR WARM UP AND GEAR OIL STARTED LEAKING OUT OF TRANSMISSION. OIL WAS LEAKING BETWEEN SEASONAL DISCONNECT AND BOTTOM PAN FOR PTO SHAFT GEAR FROM HOUSING HOLE WITH NO PLUG. FRONT OF TRANS THERE IS A FILL PLUG UNDER CLUTCH PEDAL LINKAGE, IF I REMOVE THE PLUG AND START THE TRACTOR FLUID APPEARS LIKE ITS BEING PUMPED OUT OF HOLE,SUSPECT GEAR IS SLINGING OIL. TRACTOR HAS NEVER DONE THIS BEFORE AND I WAS WONDERING IF I JUST OVERFILLED THE TRANS AND REAR DIFF, OR IS THERE A SEAL LEAKING INSIDE OF TRANS. THANKS FOR ANY HELP.
