I am having a few issues with my Chevy truck, and decided it was time to check on the battery and alternator. Went to Autozone for load test on both, and the counter guy brought out a hand held tester, checked both and said they tested good. I had them test a vehicle there before, but then they used a roll out cart that had a lot more equipment, and the test for the alternator called for engine to be run up to 2000 rpm's and held there for a few seconds to get a reading. The hand held tester was only used while truck idled.
Can a battery and alternator be accurately tested this way? I am not sure I trust the results when the test is only run at idle, and doesn't read the electrical system at operating conditions. The alternator showed it was putting out about 36 amps, and it is supposed to be a 100 amp alternator. When I asked the guy about the difference, he said it was charging and the reading was normal, even though the engine was only at idle. I just don't see how an alternator can be tested without the engine being up to normal operating rpms.
Am I wrong about the testing method? I want to keep my electrical system in working order as this is my daily driver and I don't want to end up broke down on the side of the road, or get off from work to find a dead battery with no way to get it going. I would appreciate your thoughts and opinions on this, and if anyone has suggestions for a better method to test my electrical system I would be glad to here about it.
Thanks in advance.
Thanks in advance.
