Hey all,
I was given 2 floor jacks by a relative a few weeks ago. I started investigating into one tonight as to why it doesn't want to lift and what I found is this:
JACK #1
Jack shows no visible signs of leaking (IE dust/dirt buildup)
Seems to be nearly full on oil.
Seems to jack no harder/easier than my working floor jack.
I tried it tonight, and with the "fill plug" removed, if you stroke the handle, you can see the fluid go down slightly (like it is pumping the oil) but as soon as you lift the handle back up to take another stroke you can see the oil level in the reservoir rise, like the fluid is not entering the cylinder itself.. as it makes NO ATTEMPT to raise. Lift/lower valve seems to be closed all the way.
JACK #2
I have not looked too deep into this one yet, but this one as you stroke the handle, the jack will raise, and as soon as you bring the handle back up, the jack falls back to original location.. IMMEDIATELY.. not slowly.. it drops as slow/fast as you pump the handle. Again, shows little/no signs of leaking oil.
Both of these jacks appear to be of pretty good quality, so if I could fix em reasonably I'd sure like to..
Anyone got any pointers on where to begin with either unit? I have a feeling they both have about the same issue.
TIA,
Brad
JACK #1
JACK #2
TIA,
Brad
