Hobo,NC
- Location
- Sanford, NC
It was in my press and failed to pump up,,, if you short stroked it for awhile it would catch and do the job one time no problem,,, full of oil... I removed it and took out the release and pump and flushed it well,,, got some rust and junk out of it,,, put it back together bleed it and it worked one time great but back to have'n to short stroke it to make it work,,, I could not get the Allen plugs out it has 2 of'em,,, I would break the A wrench try'n,,, I know I am gonna have to get at the check balls to do a better clean'n are replacement of the intake check ball,,, I am sure the check ball for the piston side is OK,,, I think it pulls the fluid into the pump on the up?intake stroke but does not check it off and pushes it back into the reservoir,,, I have 2 other jacks do'n the same thing,,, I spec I have outlived them and the rust is the big issue... Chines jack is look'n good rite now and wondering if my time is worth it,,, any tips on the Allen plugs are were the check valve/balls might B...
Lincoln/Walker 25 Ton Bottle jack model # 93234
