austins2010
New User
I am working on a Massey Ferguson MF80B Backhoe way up in the mountains of Northern Colorado. I am trying to get it running for a WWII hero who is 89 years old and has Parkinson's Disease and Alzheimers. I'm trying to put some value to his property instead of it just being useless pieces of metal.
I'm trying to straighten out two wires coming off of the starter solenoid and one wire coming off of the ignition.
All three are hanging loose
I have been to Massey Ferguson here in Greeley, CO and got a copy of the wiring diagram for a MF80B TLB; but, when I compare what the wiring diagram shows and the wiring on the backhoe, there is no comparison. So, I'm in a quandry.
What I need to know is where each of two black 12 mil wires, each connected to it's own terminal on either side of the positive connection from the battery go to. Each of the black wires is about 8-10 inches long and are just hanging off of the starter solenoid.
The third wire is a tan or faded yellow 10 mil wire coming from the ignition switch on the instrument panel inside the cab and going to the left side of the engine near where the two black wires from the starter solenoid are--close enough that they could all be connected to each other.
I tried that, but I still couldn't get the starter to operate. The batteries are good on properly connected.
What I need to know is where these three wires go to that I can get some power to the starter motor. This is also the model that has a starter button to the left of the ignition, both of which are on the left hand side of the steering wheel on the instrument.
Any help would sincerely be appreciated.
